Introduzione
Replacing the battery is a very simple process and doesn't require any tools to remove. For other replacement guides however, it is imperative to remove the battery before other components to reduce the risk of shock.
Slide the two release latches on either side of the battery.
Gently tilt the battery upward and remove it from its socket.
Altre 2 persone hanno completato questa guida.
