Salta al contenuto principale
HP ProBook 4540s Back Door Replacement
Cosa ti serve
  1. HP ProBook 4540s Back Door Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Back Door Replacement, Bottom Door: passo 2, immagine 1 di 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
Amber Schindler
Membro da: 10/26/16
1.027 Reputazione
6 Guide realizzate
UW Tacoma, Team 1-5, Rose Fall 2016 Membro di UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,100
