Salta al contenuto principale
HP ProBook 4530s WiFi Card Replacement
Cosa ti serve
  1. HP ProBook 4530s WiFi Card Replacement, Introduction: passo 1, immagine 1 di 2 HP ProBook 4530s WiFi Card Replacement, Introduction: passo 1, immagine 2 di 2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s WiFi Card Replacement, Battery Removal: passo 2, immagine 1 di 1
    • Push both switches inward. The battery should pop out a slight amount.
    • Pull out the battery.
  3. HP ProBook 4530s WiFi Card Replacement, Back Panel Removal: passo 3, immagine 1 di 1
    • Press on both of the battery switches then push on the back panel forward.
    • It should pop out slightly.
    • Lift and slide the panel off.
  4. HP ProBook 4530s WiFi Card Replacement, Connector Removal: passo 4, immagine 1 di 2 HP ProBook 4530s WiFi Card Replacement, Connector Removal: passo 4, immagine 2 di 2
    • Locate the WiFi card outlined in red.
    • The golden connectors will need to be popped off. They are marked in blue.
    • Be very careful. If these connectors break, you will have to buy entirely new wires and connectors.
    • Use a nail, a flat-head screwdriver, anything that will be able to pop off the connector gently.
  5. HP ProBook 4530s WiFi Card Replacement, Card Removal: passo 5, immagine 1 di 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: passo 5, immagine 2 di 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: passo 5, immagine 3 di 3
    • Remove the two screws that secure the card down.
    • The card should pop up at a 45 degree angle.
    • Pull the card straight out.
Conclusione
Altre 5 persone hanno completato questa guida.
Drew Canada
Membro da: 04/03/18
1.370 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 40
Tutti i Tempi: 3,677
