1. Start by flipping the laptop over onto its back.
    • Start by flipping the laptop over onto its back.
  2. Press in on both sides, the switches will release the battery.
    • Press in on both sides, the switches will release the battery.
    • The battery will pop out slightly, allowing you to pull it out.
    • Press in on both switches, while pushing onto the plastic panel behind them.
    • The panel should slide out.
    • Locate the RAM slightly to the center-left.
    • Press outward on the metal retention arms for the RAM.
    • The RAM should pop upward slightly.
    • Grab the RAM gently and remove at a 45 Degree angle.
Conclusione
Altre 4 persone hanno completato questa guida.
Drew Canada
Membro da: 03/04/2018
968 Reputazione
4 Guide realizzate
Here are the best function for need to save the all setting of control panel in windows 10 this is the way for provide the all feature to use the application many people have to visit here and follow the information.
shubham rock - Replica
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 171
