Salta al contenuto principale
HP ProBook 4530s Hard Drive Replacement
Cosa ti serve
  1. HP ProBook 4530s Hard Drive Replacement, Introduction: passo 1, immagine 1 di 2 HP ProBook 4530s Hard Drive Replacement, Introduction: passo 1, immagine 2 di 2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s Hard Drive Replacement, Battery Removal: passo 2, immagine 1 di 2 HP ProBook 4530s Hard Drive Replacement, Battery Removal: passo 2, immagine 2 di 2
    • Press inward on the two switches.
    • The battery should pop out slightly.
    • Remove the battery.
  3. HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: passo 3, immagine 1 di 2 HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: passo 3, immagine 2 di 2
    • Press inward on both switches while pushing the center panel away from you. It should slide slightly backwards.
    • Release the switches.
    • Slide the panel the rest of the way out.
  4. HP ProBook 4530s Hard Drive Replacement, Removing HDD: passo 4, immagine 1 di 2 HP ProBook 4530s Hard Drive Replacement, Removing HDD: passo 4, immagine 2 di 2
    • Unscrew the four screws located on the edges of the base.
    • Lift enough on the right side of the HDD to make it over the plastic paneling.
    • Pull outward.
  5. HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: passo 5, immagine 1 di 3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: passo 5, immagine 2 di 3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: passo 5, immagine 3 di 3
    • Remove the adhesive from the protective covering over the HDD.
    • Remove the four screws around the edges of the metal base.
    • Pull out the HDD from the base.
  6. HP ProBook 4530s Hard Drive Replacement, Conclusion: passo 6, immagine 1 di 1
    • Insert the new HDD or SSD.
Conclusione
Altre 8 persone hanno completato questa guida.
Drew Canada
Membro da: 04/03/18
1.433 Reputazione
4 Guide realizzate
2 Commenti
Clear and easy instructions. It’s nice to encounter a computer with such easy access to the internals.
Lensyl Urbano - Replica
You have saved me time and money from going to my engineer to help me out. Thank you.
Mercy Ayinde - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 54
Tutti i Tempi: 13,074
