Introduzione
"Prerequisite Only"
Learn to replace the palm rest of the HP ProBook 4520s. The palm rest includes the touchpad which is used to move the cursor on the screen.
Cosa ti serve
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
Use a Phillips #1 screwdriver to remove the three 3mm screws along the top of the palm rest.
