Salta al contenuto principale
HP ProBook 4520s Keyboard Replacement
Cosa ti serve
  1. HP ProBook 4520s Keyboard Replacement, Battery: passo 1, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Keyboard Replacement, Switch Cover: passo 3, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement, Switch Cover: passo 3, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Keyboard Replacement: passo 4, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement: passo 4, immagine 2 di 2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Keyboard Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Keyboard Replacement: passo 6, immagine 1 di 3 HP ProBook 4520s Keyboard Replacement: passo 6, immagine 2 di 3 HP ProBook 4520s Keyboard Replacement: passo 6, immagine 3 di 3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. HP ProBook 4520s Keyboard Replacement, Keyboard: passo 7, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement, Keyboard: passo 7, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
  8. HP ProBook 4520s Keyboard Replacement: passo 8, immagine 1 di 1
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
  9. HP ProBook 4520s Keyboard Replacement: passo 9, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement: passo 9, immagine 2 di 2
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
Conclusione
To reassemble your device, follow these steps in reverse order.
Altre 7 persone hanno completato questa guida.
UC Davis, Team 1-3, Oliver Fall 2016 Membro di UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Membri
8 Guide realizzate
Un commento
hp probook 4520s disassembly
https://youtu.be/8749zmz0lls
mohamed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,584
