Salta al contenuto principale
HP ProBook 450 G4 Speaker Replacement
Cosa ti serve
  1. HP ProBook 450 G4 Speaker Replacement, Hard Drive: passo 1, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Speaker Replacement: passo 2, immagine 1 di 3 HP ProBook 450 G4 Speaker Replacement: passo 2, immagine 2 di 3 HP ProBook 450 G4 Speaker Replacement: passo 2, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Speaker Replacement: passo 3, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 3, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Speaker Replacement: passo 4, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 4, immagine 2 di 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Speaker Replacement, Keyboard: passo 5, immagine 1 di 3 HP ProBook 450 G4 Speaker Replacement, Keyboard: passo 5, immagine 2 di 3 HP ProBook 450 G4 Speaker Replacement, Keyboard: passo 5, immagine 3 di 3
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Speaker Replacement: passo 6, immagine 1 di 3 HP ProBook 450 G4 Speaker Replacement: passo 6, immagine 2 di 3 HP ProBook 450 G4 Speaker Replacement: passo 6, immagine 3 di 3
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Speaker Replacement: passo 7, immagine 1 di 3 HP ProBook 450 G4 Speaker Replacement: passo 7, immagine 2 di 3 HP ProBook 450 G4 Speaker Replacement: passo 7, immagine 3 di 3
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Speaker Replacement: passo 8, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 8, immagine 2 di 2
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
  9. HP ProBook 450 G4 Speaker Replacement, Battery: passo 9, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement, Battery: passo 9, immagine 2 di 2
    • Flip the laptop back over.
    • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
  10. HP ProBook 450 G4 Speaker Replacement: passo 10, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 10, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
  11. HP ProBook 450 G4 Speaker Replacement: passo 11, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 11, immagine 2 di 2
    • Use the spudger to slide the disk drive out of the laptop.
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
  12. HP ProBook 450 G4 Speaker Replacement: passo 12, immagine 1 di 3 HP ProBook 450 G4 Speaker Replacement: passo 12, immagine 2 di 3 HP ProBook 450 G4 Speaker Replacement: passo 12, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
  13. HP ProBook 450 G4 Speaker Replacement: passo 13, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 13, immagine 2 di 2
    • Flip the laptop back over so it is facing upwards.
    • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
  14. HP ProBook 450 G4 Speaker Replacement: passo 14, immagine 1 di 3 HP ProBook 450 G4 Speaker Replacement: passo 14, immagine 2 di 3 HP ProBook 450 G4 Speaker Replacement: passo 14, immagine 3 di 3
    • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
    • Be extra careful while disconnecting the cable connectors because they can tear easily.
  15. HP ProBook 450 G4 Speaker Replacement: passo 15, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 15, immagine 2 di 2
    • Insert the spudger in between the top case of the laptop and its outer frame.
    • Slide the spudger around the edge of the laptop until the top case comes off.
    • Remove the top case.
  16. HP ProBook 450 G4 Speaker Replacement: passo 16, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 16, immagine 2 di 2
    • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
  17. HP ProBook 450 G4 Speaker Replacement, Speaker: passo 17, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement, Speaker: passo 17, immagine 2 di 2
    • Orient the top case of the laptop so that the internal parts are facing upwards and green rectangular object is closer to you.
    • Identify the two speakers at the top.
  18. HP ProBook 450 G4 Speaker Replacement: passo 18, immagine 1 di 3 HP ProBook 450 G4 Speaker Replacement: passo 18, immagine 2 di 3 HP ProBook 450 G4 Speaker Replacement: passo 18, immagine 3 di 3
    • Use the Phillips #0 Screwdriver to remove the two 3.5mm screws connecting the speakers to the top case of the laptop.
  19. HP ProBook 450 G4 Speaker Replacement: passo 19, immagine 1 di 2 HP ProBook 450 G4 Speaker Replacement: passo 19, immagine 2 di 2
    • Insert the spudger underneath each speaker to detach them from the top case of the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Sebastian Dow
Membro da: 01/23/20
1.043 Reputazione
6 Guide realizzate
Cal Poly, Team S1-G3, White Winter 2020 Membro di Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Membri
18 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 40
Tutti i Tempi: 867
