Introduzione
Updating your Wi-Fi Card can give you a faster connection and greater range. Allowing your computer to take full advantage of high speed internet.
Parti
Nessuna parte richiesta.
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Aggiungi Commento
Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
Aggiungi Commento
  • Flip laptop over and open it.
Aggiungi Commento
  • Slightly push up while lifting up on the power button panel to release the panel.
Aggiungi Commento
  • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Aggiungi Commento
  • Carefully (holding both sides of the keyboard), push up and lift slightly.
  • Keyboard is still connected via a ribbon cable.
  • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Aggiungi Commento
  • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Aggiungi Commento
  • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
Aggiungi Commento
  • Carefully slide the bottom panel to the right.
  • Keyboard is connected via a wire to the back of the panel.
Aggiungi Commento
  • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
  • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
Aggiungi Commento
  • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
Aggiungi Commento
  • Use black spudger to detach the two antenna cable connectors to the Wi-Fi card.
  • Be careful not to break the cords.
Aggiungi Commento
  • Unscrew the two (2.5 mm Phillips) screws holding the wifi card in.
  • Be careful because upon the last turn of the screw, the Wi-Fi card lifts up slightly.
Aggiungi Commento
  • Pull the Wi-Fi card towards the left to remove.
Aggiungi Commento
Conclusione
Joshua
Membro da: 23/09/2014
88 Reputazione
6 Guide realizzate
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro di USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 409
