Salta al contenuto principale
HP ProBook 4320t Speakers Replacement Guide
Cosa ti serve
  1. HP ProBook 4320t Speakers Replacement Guide, Battery Removal: passo 1, immagine 1 di 2 HP ProBook 4320t Speakers Replacement Guide, Battery Removal: passo 1, immagine 2 di 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Speakers Replacement Guide, Screws: passo 2, immagine 1 di 2 HP ProBook 4320t Speakers Replacement Guide, Screws: passo 2, immagine 2 di 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Speakers Replacement Guide, Flip: passo 3, immagine 1 di 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Speakers Replacement Guide, Push N Lift: passo 4, immagine 1 di 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Speakers Replacement Guide, Unscrewing: passo 5, immagine 1 di 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Speakers Replacement Guide, Careful Now: passo 6, immagine 1 di 2 HP ProBook 4320t Speakers Replacement Guide, Careful Now: passo 6, immagine 2 di 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Speakers Replacement Guide, Disconnect Wire: passo 7, immagine 1 di 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Speakers Replacement Guide, Speakers: passo 8, immagine 1 di 1
    • Use the black spudger tool to lift the white, black, and red ribbon cable connector up so that it is disconnected.
  9. HP ProBook 4320t Speakers Replacement Guide: passo 9, immagine 1 di 1
    • Unscrew the two (2.5 mm Phillips) screws (located on the upper most part of the computer) holding the speakers in.
  10. HP ProBook 4320t Speakers Replacement Guide: passo 10, immagine 1 di 1
    • Using the black spudger tool, gently pry off the right speaker.
    • Be careful to not break the cord.
  11. HP ProBook 4320t Speakers Replacement Guide: passo 11, immagine 1 di 1
    • Remove the cords from the retention clips.
  12. HP ProBook 4320t Speakers Replacement Guide: passo 12, immagine 1 di 1
    • Remove the left speaker as completed in step #10.
Conclusione
Eric Markham
Membro da: 08/29/14
227 Reputazione
4 Guide realizzate
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro di USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 544
