Salta al contenuto principale
HP ProBook 4320t Processor Heat Sink Replacement Guide
Cosa ti serve
  1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: passo 1, immagine 1 di 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: passo 1, immagine 2 di 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: passo 2, immagine 1 di 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: passo 2, immagine 2 di 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Flip: passo 3, immagine 1 di 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Push N Lift: passo 4, immagine 1 di 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrewing: passo 5, immagine 1 di 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: passo 6, immagine 1 di 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: passo 6, immagine 2 di 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: passo 7, immagine 1 di 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrew: passo 8, immagine 1 di 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Processor Heat Sink Replacement Guide, Slide the Panel Off: passo 9, immagine 1 di 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Processor Heat Sink Replacement Guide, Lift up Carefully: passo 10, immagine 1 di 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: passo 11, immagine 1 di 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Processor Heat Sink Replacement Guide, Computer Fan: passo 12, immagine 1 di 1
    • Locate silver holding panel on the left side of the computer.
  13. HP ProBook 4320t Processor Heat Sink Replacement Guide: passo 13, immagine 1 di 1
    • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
    • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
  14. HP ProBook 4320t Processor Heat Sink Replacement Guide: passo 14, immagine 1 di 1
    • Remove holding panel and put aside.
  15. HP ProBook 4320t Processor Heat Sink Replacement Guide: passo 15, immagine 1 di 1
    • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
  16. HP ProBook 4320t Processor Heat Sink Replacement Guide: passo 16, immagine 1 di 1
    • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
  17. HP ProBook 4320t Processor Heat Sink Replacement Guide: passo 17, immagine 1 di 1
    • Lift fan up carefully and replace.
  18. HP ProBook 4320t Processor Heat Sink Replacement Guide, Processor Heat Sink: passo 18, immagine 1 di 1
    • Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
  19. HP ProBook 4320t Processor Heat Sink Replacement Guide: passo 19, immagine 1 di 1
    • Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
Conclusione
Eric Markham
Membro da: 08/29/14
227 Reputazione
4 Guide realizzate
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro di USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,065
