Salta al contenuto principale
HP ProBook 4320t Clock Battery Replacement Guide
Cosa ti serve
  1. HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: passo 1, immagine 1 di 2 HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: passo 1, immagine 2 di 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Clock Battery Replacement Guide, Screws: passo 2, immagine 1 di 2 HP ProBook 4320t Clock Battery Replacement Guide, Screws: passo 2, immagine 2 di 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Clock Battery Replacement Guide, Flip: passo 3, immagine 1 di 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Clock Battery Replacement Guide, Push N Lift: passo 4, immagine 1 di 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Clock Battery Replacement Guide, Unscrewing: passo 5, immagine 1 di 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: passo 6, immagine 1 di 2 HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: passo 6, immagine 2 di 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: passo 7, immagine 1 di 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Clock Battery Replacement Guide, Unscrew: passo 8, immagine 1 di 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Clock Battery Replacement Guide, Slide the Panel Off: passo 9, immagine 1 di 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Clock Battery Replacement Guide, Lift up Carefully: passo 10, immagine 1 di 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: passo 11, immagine 1 di 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Clock Battery Replacement Guide, Detach Cables: passo 12, immagine 1 di 1
    • Using the black spudger, detach the two antenna cable connectors leading to the Wi-Fi card (this is to access the clock battery without causing damage to the cords).
  13. HP ProBook 4320t Clock Battery Replacement Guide, Pop it Out: passo 13, immagine 1 di 1
    • Using your black spudger, gently press down and towards you until the battery slides out.
    • Put new clock battery in and reassemble.
Conclusione
Altre 2 persone hanno completato questa guida.
Joshua
Membro da: 09/23/14
134 Reputazione
6 Guide realizzate
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro di USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,003
