Salta al contenuto principale
HP Photosmart c3180 Control Panel Circuitry Replacement
Cosa ti serve
  1. HP Photosmart c3180 Control Panel Circuitry Replacement, Top Panel: passo 1, immagine 1 di 2 HP Photosmart c3180 Control Panel Circuitry Replacement, Top Panel: passo 1, immagine 2 di 2
    • Before disassembling your printer, be sure that the printer has been unplugged.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 2, immagine 1 di 2 HP Photosmart c3180 Control Panel Circuitry Replacement: passo 2, immagine 2 di 2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 3, immagine 1 di 2 HP Photosmart c3180 Control Panel Circuitry Replacement: passo 3, immagine 2 di 2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 4, immagine 1 di 2 HP Photosmart c3180 Control Panel Circuitry Replacement: passo 4, immagine 2 di 2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 5, immagine 1 di 2 HP Photosmart c3180 Control Panel Circuitry Replacement: passo 5, immagine 2 di 2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 6, immagine 1 di 1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 7, immagine 1 di 2 HP Photosmart c3180 Control Panel Circuitry Replacement: passo 7, immagine 2 di 2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 8, immagine 1 di 2 HP Photosmart c3180 Control Panel Circuitry Replacement: passo 8, immagine 2 di 2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 9, immagine 1 di 1
    • Carefully lift the top panel of the printer away from the printer body.
  10. HP Photosmart c3180 Control Panel Circuitry Replacement, Control Panel Circuitry: passo 10, immagine 1 di 1
    • Set aside the printer body.
    • Remove the three T10 12 mm Torx screws from the back of control panel circuit board.
  11. HP Photosmart c3180 Control Panel Circuitry Replacement: passo 11, immagine 1 di 1
    • Using both hands, carefully lift the control panel circuit board from the top panel of the printer.
Conclusione
Altre 4 persone hanno completato questa guida.
Jim
Membro da: 10/06/11
1.557 Reputazione
10 Guide realizzate
Cal Poly, Team 20-30, Maness Fall 2011 Membro di Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Membri
25 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,385
