Salta al contenuto principale
HP Photosmart Premium C309g Scanner Replacement
Cosa ti serve
  1. HP Photosmart Premium C309g Scanner Replacement, Scanner: passo 1, immagine 1 di 1
    • Open the top of the printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g Scanner Replacement: passo 2, immagine 1 di 2 HP Photosmart Premium C309g Scanner Replacement: passo 2, immagine 2 di 2
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g Scanner Replacement: passo 3, immagine 1 di 2 HP Photosmart Premium C309g Scanner Replacement: passo 3, immagine 2 di 2
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g Scanner Replacement: passo 4, immagine 1 di 1
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g Scanner Replacement: passo 5, immagine 1 di 1
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g Scanner Replacement: passo 6, immagine 1 di 1
    • Lift the scanner glass piece from the printer and set it aside.
  7. HP Photosmart Premium C309g Scanner Replacement: passo 7, immagine 1 di 2 HP Photosmart Premium C309g Scanner Replacement: passo 7, immagine 2 di 2
    • Gently pick up the scanner piece as shown to see the bottom side and wiring.
  8. HP Photosmart Premium C309g Scanner Replacement: passo 8, immagine 1 di 2 HP Photosmart Premium C309g Scanner Replacement: passo 8, immagine 2 di 2
    • Gently remove the 2 wire ribbons shown by pulling them away from the scanner piece.
Conclusione
Charles
Membro da: 10/23/14
371 Reputazione
2 Guide realizzate
Michigan Tech, Team 1-2, Lauer Fall 2014 Membro di Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,312
