Introduzione
If the scanner glass cracks or breaks, it will need to be replaced in it's entirety. The glass is visible when you open the top of the printer so you will be able to tell if it needs replacement without taking the printer apart.
Cosa ti serve
The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
Both clips will come unattached and you can set the scanner flap aside.
