Introduzione
You will need to remove many parts of the computer. The key is to be careful when removing some parts of the computer.
Cosa ti serve
Shut down the computer.
Turn computer upside down so the base is facing upward.
Position the computer so the front is towards you.
Remove two 5mm Phillips #1 screws
Slide the hard drive cover towards the empty battery spot and remove it.
Remove one Phillips M2.5X5.0 Screw that is securing the optical drive.
With the nylon spudger, push the optical drive until you can grab it.
Pull the optical drive all the way out, until removed.
Remove 2 Phillips M2.5X6.5 screws from the back of the computer.
Turn the computer over, and open the computer as far as possible without breaking it.
Release the top of the keyboard by lifting up and gently pull the top up until the whole keyboard is up.
Lift plastic cover to release the ZIF connector that is holding the keyboard in place. Then remove the keyboard.
Release 2 ZIF connectors where the touch pad cable and fingerprint reader are connected.
Remove 4 Phillips M2.0X4.0 screws near the top of the keyboard area.
Lift top cover from the base and release the ZIF connector that the power button is connected to. The cover should now be removed.
