Introduzione
You will have to remove many parts of the computer. Be sure to be careful when removing the parts so not to damage them.
Cosa ti serve
Shut down the computer.
Turn computer upside down so the base is facing upward.
Position the computer so the front is towards you.
Remove two 5mm Phillips #1 screws
Slide the hard drive cover towards the empty battery spot and remove it.
Remove one Phillips M2.5X5.0 Screw that is securing the optical drive.
With the nylon spudger, push the optical drive until you can grab it and pull it all the way out.
