Introduzione
To detach the memory you will need a Phillips PH1 screwdriver. Also remember to be gentle with the screws because not all of them will completely detach from the plastic.
Cosa ti serve
Shut down the computer.
Turn computer upside down so the base is facing upward.
Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
Slide cover toward empty battery area and remove it.
Quasi finito!
Conclusione
