Salta al contenuto principale
HP Pavillion dm4t-2100 Hard Drive
Cosa ti serve
  1. HP Pavillion dm4t-2100 Hard Drive, Battery: passo 1, immagine 1 di 2 HP Pavillion dm4t-2100 Hard Drive, Battery: passo 1, immagine 2 di 2
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Hard Drive: passo 2, immagine 1 di 3 HP Pavillion dm4t-2100 Hard Drive: passo 2, immagine 2 di 3 HP Pavillion dm4t-2100 Hard Drive: passo 2, immagine 3 di 3
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Hard Drive, Hard Drive: passo 3, immagine 1 di 3 HP Pavillion dm4t-2100 Hard Drive, Hard Drive: passo 3, immagine 2 di 3 HP Pavillion dm4t-2100 Hard Drive, Hard Drive: passo 3, immagine 3 di 3
    • Position the computer so the front is towards you.
    • Remove two 5mm Phillips #1 screws
    • Slide the hard drive cover towards the empty battery spot and remove it.
  4. HP Pavillion dm4t-2100 Hard Drive: passo 4, immagine 1 di 3 HP Pavillion dm4t-2100 Hard Drive: passo 4, immagine 2 di 3 HP Pavillion dm4t-2100 Hard Drive: passo 4, immagine 3 di 3
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  5. HP Pavillion dm4t-2100 Hard Drive: passo 5, immagine 1 di 1
    • Disconnect the hard drive cable that is plugged in.
    • Lift the tab on the hard drive to pull it out of the computer.
    • Hard Drive is removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 480
