Salta al contenuto principale
HP Pavillion dm1-3010nr Hard Drive Replacement
Cosa ti serve
  1. HP Pavillion dm1-3010nr Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Hard Drive Replacement: passo 2, immagine 1 di 1
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • With the battery removed, the back cover can be taken off with your hand.
  4. HP Pavillion dm1-3010nr Hard Drive Replacement: passo 4, immagine 1 di 1
    • Use your Phillips 0 screwdriver to remove the four 2.5mm Phillips screws which hold the hard drive in place. You can see the 4 screws in the picture circled in red.
  5. HP Pavillion dm1-3010nr Hard Drive Replacement: passo 5, immagine 1 di 1
    • To disconnect the hard drive from the motherboard, pull the black tab as seen in the picture.
  6. HP Pavillion dm1-3010nr Hard Drive Replacement: passo 6, immagine 1 di 2 HP Pavillion dm1-3010nr Hard Drive Replacement: passo 6, immagine 2 di 2
    • After removing the enclosure from the device, use your Phillips 0 screwdriver to remove four 3mm Phillips screws. There are two screws on each side of the hard drive enclosure.
Conclusione
Amitpal Gill
Membro da: 10/22/18
375 Reputazione
3 Guide realizzate
UC Davis, Team S7-G1, Lore Fall 2018 Membro di UC Davis, Team S7-G1, Lore Fall 2018
UCD-LORE-F18S7G1
3 Membri
4 Guide realizzate
Un commento
Schritt 5 ist leider komplett falsch. Der SATA-Stecker muss von der Festplatte/SSD gezogen werden. Nicht irgendein Kabel vom Motherboard. Den Stecker zieht man einfacher von der HDD/SSD weg, wenn man zuerst Schritt #6 ausführt, dann ist die Metall-Lasche am Kopf des Steckers nicht mehr im Weg.
Peter C. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,259
