Salta al contenuto principale
HP Pavillion dm1-3010nr Cooling Fan Replacement
Cosa ti serve
  1. HP Pavillion dm1-3010nr Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Cooling Fan Replacement: passo 2, immagine 1 di 1
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Cooling Fan Replacement, Cooling Fan: passo 3, immagine 1 di 1
    • With the battery removed, the bottom cover can be opened with your hand.
  4. HP Pavillion dm1-3010nr Cooling Fan Replacement: passo 4, immagine 1 di 2 HP Pavillion dm1-3010nr Cooling Fan Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a screwdriver from your iFixit Toolkit to remove the two 5mm Phillips #0 screws shown in each picture.
    • Use tweezers to carefully remove the fan's power cable from the motherboard. The cable can be seen in the second picture.
  5. HP Pavillion dm1-3010nr Cooling Fan Replacement: passo 5, immagine 1 di 1
    • After removing the screws and unplugging the wire, remove the fan.
Conclusione
Amitpal Gill
Membro da: 10/22/18
375 Reputazione
3 Guide realizzate
UC Davis, Team S7-G1, Lore Fall 2018 Membro di UC Davis, Team S7-G1, Lore Fall 2018
UCD-LORE-F18S7G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 613
