Salta al contenuto principale
HP Pavillion 15-ay041wm Speakers Replacement
Cosa ti serve
  1. HP Pavillion 15-ay041wm Speakers Replacement, Battery: passo 1, immagine 1 di 2 HP Pavillion 15-ay041wm Speakers Replacement, Battery: passo 1, immagine 2 di 2
    • Place the laptop upside down.
  2. HP Pavillion 15-ay041wm Speakers Replacement: passo 2, immagine 1 di 2 HP Pavillion 15-ay041wm Speakers Replacement: passo 2, immagine 2 di 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavillion 15-ay041wm Speakers Replacement: passo 3, immagine 1 di 3 HP Pavillion 15-ay041wm Speakers Replacement: passo 3, immagine 2 di 3 HP Pavillion 15-ay041wm Speakers Replacement: passo 3, immagine 3 di 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavillion 15-ay041wm Speakers Replacement, Disc Drive: passo 4, immagine 1 di 1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavillion 15-ay041wm Speakers Replacement: passo 5, immagine 1 di 3 HP Pavillion 15-ay041wm Speakers Replacement: passo 5, immagine 2 di 3 HP Pavillion 15-ay041wm Speakers Replacement: passo 5, immagine 3 di 3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: passo 6, immagine 1 di 3 HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: passo 6, immagine 2 di 3 HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: passo 6, immagine 3 di 3
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
  7. HP Pavillion 15-ay041wm Speakers Replacement, Speakers: passo 7, immagine 1 di 3 HP Pavillion 15-ay041wm Speakers Replacement, Speakers: passo 7, immagine 2 di 3 HP Pavillion 15-ay041wm Speakers Replacement, Speakers: passo 7, immagine 3 di 3
    • Using tweezers, disconnect the left speakers from the motherboard.
    • Remove the left and right speakers from the laptop.
  8. HP Pavillion 15-ay041wm Speakers Replacement: passo 8, immagine 1 di 2 HP Pavillion 15-ay041wm Speakers Replacement: passo 8, immagine 2 di 2
    • Slide the wires connecting both speakers out from the black stoppers.
    • You can now replace the speakers.
Conclusione
Olutola Yerokun Ty
Membro da: 01/16/20
135 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 140
