Salta al contenuto principale
HP Pavilion zv5000 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion zv5000 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion zv5000 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion zv5000 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 2 HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Make sure that the Pavilion is completely powered down and unplugged. Failure to do so may result in an electrical shock.
    • Using the Phillips #0 screwdriver, unscrew the two Phillips PM 2.5X6.0mm screws.
    • The two screws do not come out of the hard drive assembly, they simply disconnect the assembly from the laptop.
  5. HP Pavilion zv5000 Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion zv5000 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Place the spudger underneath the cover of the hard drive and push up gently until the hard drive pops out of place.
    • Completely remove the hard drive from its socket.
    • If the plastic spudger is not sturdy enough to pop the hard drive out of place, try carefully using the metal spudger.
Conclusione
Eliza Marks
Membro da: 10/18/16
649 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 4-6, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 Membri
5 Guide realizzate
Un commento
My hp pavilion zx5000 has a blue screen and i am unable to do anything. O. S. Is Windows.
Please help
Danny Morris - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,937
