Salta al contenuto principale
HP Pavilion zv5000 Battery Replacement
  1. HP Pavilion zv5000 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion zv5000 Battery Replacement: passo 2, immagine 2 di 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Battery Replacement: passo 3, immagine 1 di 2 HP Pavilion zv5000 Battery Replacement: passo 3, immagine 2 di 2
    • Using two fingers, pry the rest of the battery out of the socket.
Conclusione
Eliza Marks
Membro da: 10/18/16
649 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 4-6, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 Membri
5 Guide realizzate
2 Commenti
White light comes on when it is charging
Sandy Hancock - Replica
White light comes on the computer if it is charging
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,008
