Salta al contenuto principale
Introduzione
This guide is designed to replace the battery of the device: HP Pavilion ze5000. A replacement of a battery should occur if the laptop stops charging or is dead and will not respond to the device's charger. This guide can be used in case a device user wants to check the quality of the battery or replace the battery with a new battery installation. When completing this guide, ensure that the device is properly faced down with the back of the laptop facing the device user.
  1. Push up on the arrow-shaped switch.
    • Push up on the arrow-shaped switch.
  2. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  3. While still holding the  switch up, remove the battery. While still holding the  switch up, remove the battery.
    • While still holding the switch up, remove the battery.
Conclusione
No reassembly in required once the new battery is in.
Gabrielle
Membro da: 19/03/2018
97 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 36
