Salta al contenuto principale
HP Pavilion ze4530US Keyboard Replacement
Cosa ti serve
  1. HP Pavilion ze4530US Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Unscrew all screws on the back of the laptop.
    • There should be a total of 22 screws.
  2. HP Pavilion ze4530US Keyboard Replacement: passo 2, immagine 1 di 2 HP Pavilion ze4530US Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove all the protective covers such as the RAM protective cover.
    • Then remove the battery by pushing up on the battery release switch and pull the battery out.
  3. HP Pavilion ze4530US Keyboard Replacement: passo 3, immagine 1 di 1
    • Wedge open the top panel located above the keyboard.
    • This piece will not come off.
    • 5 screws should be visible under the lifted panel. Unscrew all screws attaching the keyboard to the laptop.
  4. HP Pavilion ze4530US Keyboard Replacement: passo 4, immagine 1 di 1
    • Once all the screws are taken out of the top portion of the keyboard, wedge open the keyboard on all sides of the keyboard.
  5. HP Pavilion ze4530US Keyboard Replacement: passo 5, immagine 1 di 1
    • Lift the keyboard and unplug it out of the socket.
  6. HP Pavilion ze4530US Keyboard Replacement: passo 6, immagine 1 di 1
    • You have successfully removed the keyboard.
Conclusione
Sonny Sem
Membro da: 10/11/16
356 Reputazione
3 Guide realizzate
Texas Tech, Team 38-5, Bennett Fall 2016 Membro di Texas Tech, Team 38-5, Bennett Fall 2016
TTU-BENNETT-F16S38G5
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 169
