Salta al contenuto principale
HP Pavilion zd8000 Switch Cover Replacement
Cosa ti serve
  1. HP Pavilion zd8000 Switch Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Switch Cover Replacement: passo 2, immagine 1 di 2 HP Pavilion zd8000 Switch Cover Replacement: passo 2, immagine 2 di 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: passo 3, immagine 1 di 2 HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: passo 3, immagine 2 di 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. HP Pavilion zd8000 Switch Cover Replacement: passo 4, immagine 1 di 2 HP Pavilion zd8000 Switch Cover Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  5. HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: passo 5, immagine 1 di 2 HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: passo 5, immagine 2 di 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  6. HP Pavilion zd8000 Switch Cover Replacement: passo 6, immagine 1 di 1
    • Flip the laptop over.
    • Fully open the laptop.
  7. HP Pavilion zd8000 Switch Cover Replacement: passo 7, immagine 1 di 3 HP Pavilion zd8000 Switch Cover Replacement: passo 7, immagine 2 di 3 HP Pavilion zd8000 Switch Cover Replacement: passo 7, immagine 3 di 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
Conclusione
Allie Menard
Membro da: 04/12/11
820 Reputazione
13 Guide realizzate
Cal Poly, Team 24-56, Amido Spring 2011 Membro di Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,109
