Cosa ti serve
Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
Lift the cover from the right to remove it.
Remove the 8mm Philips screw located between the hard drive and the WiFi card.
Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
Rotate it so the display is on your right and the keyboard is on your left.
Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
The switch cover should easily separate from the laptop as you run the spudger through.
Close the lid and rotate the laptop so that the vents are facing you.
Unscrew the two 8mm Philips screws below the hinges.
Find the ribbon cable on the LED board located at the top of the laptop.
You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
Rotate the laptop 90 degrees counter-clockwise
Locate the USB Module
Grip the yellow cable cover and pull it to the right to release it.
Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
Using tweezers, remove the the rigth speaker cable - the cable set on the left with red and black wires - by pulling the white connector towards you.
Altre 2 persone hanno completato questa guida.
