Salta al contenuto principale
HP Pavilion zd8000 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion zd8000 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Keyboard Replacement: passo 2, immagine 1 di 2 HP Pavilion zd8000 Keyboard Replacement: passo 2, immagine 2 di 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  4. HP Pavilion zd8000 Keyboard Replacement: passo 4, immagine 1 di 2 HP Pavilion zd8000 Keyboard Replacement: passo 4, immagine 2 di 2
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  5. HP Pavilion zd8000 Keyboard Replacement: passo 5, immagine 1 di 2 HP Pavilion zd8000 Keyboard Replacement: passo 5, immagine 2 di 2
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  6. HP Pavilion zd8000 Keyboard Replacement: passo 6, immagine 1 di 2 HP Pavilion zd8000 Keyboard Replacement: passo 6, immagine 2 di 2
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
Conclusione
Allie Menard
Membro da: 04/12/11
820 Reputazione
13 Guide realizzate
Cal Poly, Team 24-56, Amido Spring 2011 Membro di Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,107
