Salta al contenuto principale
HP Pavilion zd8000 CD/Optical Drive Replacement
Cosa ti serve
  1. HP Pavilion zd8000 CD/Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 CD/Optical Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion zd8000 CD/Optical Drive Replacement: passo 2, immagine 2 di 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 CD/Optical Drive Replacement, CD/Optical Drive: passo 3, immagine 1 di 1
    • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
  4. HP Pavilion zd8000 CD/Optical Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion zd8000 CD/Optical Drive Replacement: passo 4, immagine 2 di 2
    • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
    • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
  5. HP Pavilion zd8000 CD/Optical Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion zd8000 CD/Optical Drive Replacement: passo 5, immagine 2 di 2
    • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
Conclusione
Allie Menard
Membro da: 04/12/11
820 Reputazione
13 Guide realizzate
Cal Poly, Team 24-56, Amido Spring 2011 Membro di Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,442
