Salta al contenuto principale
HP Pavilion x360 m3-u103dx Motherboard Replacement
Cosa ti serve
  1. HP Pavilion x360 m3-u103dx Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Power the device off.
    • Flip the device over.
    • Using the plastic spudger, remove the rubber bumper to reveal 5 screws.
  2. HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 2, immagine 1 di 1
    • Using a Phillips screwdriver, remove 10 screws from the back plate.
    • Five 2.4 x 5.7 mm screws.
    • Five 2.8 x 5.0 mm screws.
  3. HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 3, immagine 1 di 3 HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 3, immagine 2 di 3 HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening tool, pry the keyboard upwards at the opening shown.
    • Then, using the metal spudger, pry around the rest of the keyboard until it is completely free.
    • Slowly, lift the entire keyboard up and away from the screen to reveal the connections and internals.
    • The connector ribbons can be damaged if the keyboard is lifted too high.
  4. HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 4, immagine 1 di 2 HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 4, immagine 2 di 2
    • Using the black nylon spudger, lift the retaining clip for each ribbon shown.
    • Lift the keyboard out of the device and out of the way.
  5. HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 5, immagine 1 di 3 HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 5, immagine 2 di 3 HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a J000 screwdriver, remove 9 screws from the motherboard.
    • Using a Y1 screwdriver, remove the 10th screw from the top of the motherboard.
    • Tweezers can be helpful to pull screws from tight areas.
    • Grounding bracelets can prevent static from harming delicate electronics.
  6. HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 6, immagine 1 di 2 HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 6, immagine 2 di 2
    • Using a spudger, flip the retaining clips for these two ribbons and gently pull them away from their sockets.
    • Using tweezers, gently pull this connector away from its socket.
  7. HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 7, immagine 1 di 2 HP Pavilion x360 m3-u103dx Motherboard Replacement: passo 7, immagine 2 di 2
    • Gently lift the entire motherboard while tilting it to the left side of the laptop.
    • Disconnect the final plug from underneath the motherboard.
    • Lift the old motherboard from the laptop completely.
Conclusione
Nicholas Bassett
Membro da: 09/03/19
145 Reputazione
1 Guida realizzata
IUPUI, Team S1-G2, Hovde Fall 2019 Membro di IUPUI, Team S1-G2, Hovde Fall 2019
IUPUI-HOVDE-F19S1G2
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 569
