Salta al contenuto principale
HP Pavilion x360 m3-u103dx Fan Replacement
Cosa ti serve
  1. HP Pavilion x360 m3-u103dx Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Power off device.
    • Flip laptop over.
  2. HP Pavilion x360 m3-u103dx Fan Replacement: passo 2, immagine 1 di 2 HP Pavilion x360 m3-u103dx Fan Replacement: passo 2, immagine 2 di 2
    • Remove the rubber foot with a Metal spudger
    • Remove 5 Phillip 2.4 x 5.7mm screws using a PH0 Phillips head screwdriver.
    • Remove 5 Phillips 2.8 x 5.0mm screws using a PH0 Phillips head screwdriver.
  3. HP Pavilion x360 m3-u103dx Fan Replacement: passo 3, immagine 1 di 3 HP Pavilion x360 m3-u103dx Fan Replacement: passo 3, immagine 2 di 3 HP Pavilion x360 m3-u103dx Fan Replacement: passo 3, immagine 3 di 3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Gently lift keyboard on the mouse pad side. Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  4. HP Pavilion x360 m3-u103dx Fan Replacement: passo 4, immagine 1 di 1
    • Remove eleven 2.0 x 4.6mm screws using the Phillips 00 Screwdriver
  5. HP Pavilion x360 m3-u103dx Fan Replacement: passo 5, immagine 1 di 3 HP Pavilion x360 m3-u103dx Fan Replacement: passo 5, immagine 2 di 3 HP Pavilion x360 m3-u103dx Fan Replacement: passo 5, immagine 3 di 3
    • Remove the motherboard gently from the base of the laptop.
    • Disconnect the fastened cables from the motherboard by carefully pushing the cable's plastic edges using the metal Spudger.
  6. HP Pavilion x360 m3-u103dx Fan Replacement: passo 6, immagine 1 di 2 HP Pavilion x360 m3-u103dx Fan Replacement: passo 6, immagine 2 di 2
    • Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
    • Remove any adhesive tape. Detach the fan/heat sink.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,327
