Salta al contenuto principale
HP Pavilion x360 m3-u103dx Daughterboard Replacement
Cosa ti serve
  1. HP Pavilion x360 m3-u103dx Daughterboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 2, immagine 1 di 2 HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 2, immagine 2 di 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 3, immagine 1 di 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 4, immagine 1 di 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 5, immagine 1 di 2 HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 5, immagine 2 di 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 6, immagine 1 di 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Spudger
    Compra
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 8, immagine 1 di 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u103dx Daughterboard Replacement, Battery: passo 9, immagine 1 di 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 10, immagine 1 di 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u103dx Daughterboard Replacement, Daughterboard: passo 11, immagine 1 di 2 HP Pavilion x360 m3-u103dx Daughterboard Replacement, Daughterboard: passo 11, immagine 2 di 2
    • Carefully disconnect the lower ribbon cable by pry the locking bar of the ZIF connector up with a spudger and pulling the cable loose.
  12. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 12, immagine 1 di 2 HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 12, immagine 2 di 2
    • Use the same procedure to disengage the skinnier ribbon cable just above the first: pry up the locking bar of the ZIF connector and slide out the cable.
  13. HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 13, immagine 1 di 2 HP Pavilion x360 m3-u103dx Daughterboard Replacement: passo 13, immagine 2 di 2
    • Remove the two screws with a Phillips #00 screwdriver.
    • Remove the daughterboard.
Conclusione
IUPUI, Team S2-G2, Wilson Summer 2019 Membro di IUPUI, Team S2-G2, Wilson Summer 2019
IUPUI-WILSON-SU19S2G2
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 652
