Salta al contenuto principale
HP Pavilion x360 m3-u103dx Battery Replacement
Cosa ti serve
  1. HP Pavilion x360 m3-u103dx Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
  2. HP Pavilion x360 m3-u103dx Battery Replacement: passo 2, immagine 1 di 1
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. HP Pavilion x360 m3-u103dx Battery Replacement: passo 3, immagine 1 di 1
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. HP Pavilion x360 m3-u103dx Battery Replacement: passo 4, immagine 1 di 3 HP Pavilion x360 m3-u103dx Battery Replacement: passo 4, immagine 2 di 3 HP Pavilion x360 m3-u103dx Battery Replacement: passo 4, immagine 3 di 3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  5. HP Pavilion x360 m3-u103dx Battery Replacement: passo 5, immagine 1 di 2 HP Pavilion x360 m3-u103dx Battery Replacement: passo 5, immagine 2 di 2
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  6. HP Pavilion x360 m3-u103dx Battery Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  7. HP Pavilion x360 m3-u103dx Battery Replacement: passo 7, immagine 1 di 2 HP Pavilion x360 m3-u103dx Battery Replacement: passo 7, immagine 2 di 2
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
Conclusione
Un commento
Can i use the laptop even without a battery??
PAPISSS PH - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 40
Tutti i Tempi: 6,845
