Salta al contenuto principale
HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement
Cosa ti serve
  1. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Keyboard: passo 1, immagine 1 di 1
    • Power off your device and disconnect all external devices connected to the laptop.
    • Working on your device while it is powered on may cause damage to the laptop or result in electric shock.
  2. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over and remove the rubber foot with a Metal Spudger.
  3. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 3, immagine 1 di 1
    • Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws
    • 7 Phillips 2.0 x 5.0 mm screws
    • Keep the different sized screws separate for future replacement.
  4. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 4, immagine 1 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 4, immagine 2 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 4, immagine 3 di 3
    • Flip the laptop back over and open it; the keyboard should be facing upwards.
    • Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
    • The keyboard is connected to the motherboard with cable ribbons, so be very gentle and careful when lifting the keyboard.
  5. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 5, immagine 1 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 5, immagine 2 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Spudger
    Compra
    • Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
    • Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  6. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 6, immagine 1 di 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 6, immagine 2 di 2
    • Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
    • Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
  7. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 7, immagine 1 di 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 7, immagine 2 di 2
    • After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
  8. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: passo 8, immagine 1 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: passo 8, immagine 2 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: passo 8, immagine 3 di 3
    • Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
    • 3 Phillips 2.0 x 4.6 mm screws
  9. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 9, immagine 1 di 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 9, immagine 2 di 2
    • Holding the lower right corner, gently lift up the battery to disconnect it from the motherboard.
  10. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, System Board (Motherboard): passo 10, immagine 1 di 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, System Board (Motherboard): passo 10, immagine 2 di 2
    • Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
    • 8 Phillips 2.0 x 4.7 mm screws.
  11. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 11, immagine 1 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 11, immagine 2 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 11, immagine 3 di 3
    • Disconnect the 3 bundle cable connectors by gently gripping the cable wires and pulling outwards.
    • Be sure to grip each of the cables equally so no single cable is overly strained.
  12. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 12, immagine 1 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 12, immagine 2 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 12, immagine 3 di 3
    Heavy-Duty Spudger
    Compra
    • Disconnect the 2 cable ribbons with the Heavy-Duty Spudger.
    • Use the purple plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  13. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 13, immagine 1 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 13, immagine 2 di 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: passo 13, immagine 3 di 3
    • Gently lift up the motherboard to disconnect it from the computer.
Conclusione
Un commento
where can I get this mother board from
Kevin Juma - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,237
