Salta al contenuto principale
HP Pavilion x360 15t-br000 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: passo 1, immagine 1 di 3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: passo 1, immagine 2 di 3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: passo 1, immagine 3 di 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Keyboard Replacement: passo 2, immagine 1 di 3 HP Pavilion x360 15t-br000 Keyboard Replacement: passo 2, immagine 2 di 3 HP Pavilion x360 15t-br000 Keyboard Replacement: passo 2, immagine 3 di 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Remove the two tapes of connected with the track board and the keyboard panel.
    • Remove the seven 2mm screws using the Phillips #0 screwdriver.
    • Remove the trackpad from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 467
