Salta al contenuto principale
HP Pavilion x360 15t-br000 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: passo 1, immagine 1 di 3 HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: passo 1, immagine 2 di 3 HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: passo 1, immagine 3 di 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Hard Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion x360 15t-br000 Hard Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion x360 15t-br000 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove four screws from the hard drive.
    • Remove the hard drive from the device.
    • At the time of creating this guide, the hard drive was not present in the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 830
