Salta al contenuto principale
HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement
Cosa ti serve
  1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: passo 1, immagine 1 di 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: passo 1, immagine 2 di 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: passo 1, immagine 3 di 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: passo 2, immagine 1 di 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: passo 2, immagine 2 di 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: passo 2, immagine 3 di 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: passo 3, immagine 1 di 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: passo 3, immagine 2 di 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: passo 3, immagine 3 di 3
    • Remove all three 3.5 mm screws using the Phillips #0 screwdriver.
    • Disconnect the cables above the fan.
    • Disconnect the wire next to the fan.
  4. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: passo 4, immagine 1 di 1
    • Remove nine 4mm screws using the Phillips #0 screwdriver.
  5. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: passo 5, immagine 1 di 1
    • Flip over the motherboard.
  6. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: passo 6, immagine 1 di 2 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: passo 6, immagine 2 di 2
    • Remove four 3.5mm screws using the Phillips #0 screwdriver.
    • Remove the fan and heatsink assembly from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 517
