Salta al contenuto principale
HP Pavilion x360 15t-br000 Battery Replacement
Cosa ti serve
  1. HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: passo 1, immagine 1 di 3 HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: passo 1, immagine 2 di 3 HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: passo 1, immagine 3 di 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Battery Replacement: passo 2, immagine 1 di 3 HP Pavilion x360 15t-br000 Battery Replacement: passo 2, immagine 2 di 3 HP Pavilion x360 15t-br000 Battery Replacement: passo 2, immagine 3 di 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 Battery Replacement: passo 4, immagine 1 di 2 HP Pavilion x360 15t-br000 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 822
