Salta al contenuto principale
HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement
Cosa ti serve
  1. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 2, immagine 1 di 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 3, immagine 1 di 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 3, immagine 2 di 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 4, immagine 1 di 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 4, immagine 2 di 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 5, immagine 1 di 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 5, immagine 2 di 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 5, immagine 3 di 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: passo 6, immagine 1 di 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: passo 6, immagine 2 di 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: passo 6, immagine 3 di 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 7, immagine 1 di 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 7, immagine 2 di 2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Heat Sink and Fan: passo 8, immagine 1 di 1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 9, immagine 1 di 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 10, immagine 1 di 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 10, immagine 2 di 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 10, immagine 3 di 3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 11, immagine 1 di 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: passo 11, immagine 2 di 2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 16
Tutti i Tempi: 551
