Salta al contenuto principale
HP Pavilion x360 14m-cd0005dx Battery Replacement
Cosa ti serve
  1. HP Pavilion x360 14m-cd0005dx Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 2, immagine 1 di 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 3, immagine 1 di 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 3, immagine 2 di 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 4, immagine 1 di 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 4, immagine 2 di 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 5, immagine 1 di 3 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 5, immagine 2 di 3 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 5, immagine 3 di 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: passo 6, immagine 1 di 3 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: passo 6, immagine 2 di 3 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: passo 6, immagine 3 di 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 7, immagine 1 di 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 7, immagine 2 di 2
    • Carefully lift from the base and remove the battery.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,529
