Salta al contenuto principale
HP Pavilion x360 14m-cd0003dx Touchpad Replacement
Cosa ti serve
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 2, immagine 1 di 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 2, immagine 2 di 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 3, immagine 1 di 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 3, immagine 2 di 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 3, immagine 3 di 3
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: passo 4, immagine 1 di 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: passo 4, immagine 2 di 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: passo 4, immagine 3 di 3
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 5, immagine 1 di 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 5, immagine 2 di 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 5, immagine 3 di 3
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 6, immagine 1 di 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: passo 6, immagine 2 di 2
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
Conclusione
Elijah Jope
Membro da: 03/22/22
379 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 15
Tutti i Tempi: 430
