Salta al contenuto principale
HP Pavilion x360 14m-cd0003dx Screen Replacement
Cosa ti serve
  1. HP Pavilion x360 14m-cd0003dx Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 3, immagine 1 di 1
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 4, immagine 1 di 2 HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 4, immagine 2 di 2
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 5, immagine 1 di 2 HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 5, immagine 2 di 2
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 6, immagine 1 di 1
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 7, immagine 1 di 3 HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 7, immagine 2 di 3 HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 7, immagine 3 di 3
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Screen Replacement: passo 8, immagine 1 di 1
    • After the cable has been disconnected, the screen can be removed.
Conclusione
Elijah Jope
Membro da: 03/22/22
379 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 12
Tutti i Tempi: 894
