Salta al contenuto principale
HP Pavilion x360 14m-cd0003dx SSD Replacement
Cosa ti serve
  1. HP Pavilion x360 14m-cd0003dx SSD Replacement, SSD: passo 1, immagine 1 di 1
    • Make sure computer is turned off
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx SSD Replacement: passo 2, immagine 1 di 3 HP Pavilion x360 14m-cd0003dx SSD Replacement: passo 2, immagine 2 di 3 HP Pavilion x360 14m-cd0003dx SSD Replacement: passo 2, immagine 3 di 3
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx SSD Replacement: passo 3, immagine 1 di 2 HP Pavilion x360 14m-cd0003dx SSD Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the 5 mm screw that secures the SSD.
  4. HP Pavilion x360 14m-cd0003dx SSD Replacement: passo 4, immagine 1 di 2 HP Pavilion x360 14m-cd0003dx SSD Replacement: passo 4, immagine 2 di 2
    • Peel back the black covering.
    • Pull out SSD.
Conclusione
Jack Benfeito
Membro da: 03/22/22
180 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 914
