Salta al contenuto principale
HP Pavilion x360 14m-cd0003dx Fan Replacement
Cosa ti serve
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: passo 2, immagine 1 di 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: passo 2, immagine 2 di 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: passo 3, immagine 1 di 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: passo 4, immagine 1 di 1
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: passo 5, immagine 1 di 1
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: passo 6, immagine 1 di 1
    • Remove the heat sink assembly from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 465
