Introduzione
If your HP Pavilion x360 14m-ba011dx laptop’s SSD is no longer functioning or perhaps you would like to expand the memory capacity of your computer, this guide will walk you through how to replace the SSD card.
Cosa ti serve
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Two 7.5 mm screws.
Three 5 mm screws.
One 6.5 mm screw.
Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
Flip the motherboard over to expose the SSD.
Using a Phillips #00 screwdriver, remove one 3 mm silver screw that holds the SSD in place.
