Salta al contenuto principale
HP Pavilion x360 14-ba253cl Display Replacement
Cosa ti serve
  1. HP Pavilion x360 14-ba253cl Display Replacement, Display: passo 1, immagine 1 di 2 HP Pavilion x360 14-ba253cl Display Replacement, Display: passo 1, immagine 2 di 2
    • Insert an opening pick between the screen and top case to separate it from the laptop.
  2. HP Pavilion x360 14-ba253cl Display Replacement: passo 2, immagine 1 di 3 HP Pavilion x360 14-ba253cl Display Replacement: passo 2, immagine 2 di 3 HP Pavilion x360 14-ba253cl Display Replacement: passo 2, immagine 3 di 3
    • Once the screen is pryed away from the laptop, lay the screen face down onto the keyboard.
  3. HP Pavilion x360 14-ba253cl Display Replacement: passo 3, immagine 1 di 3 HP Pavilion x360 14-ba253cl Display Replacement: passo 3, immagine 2 di 3 HP Pavilion x360 14-ba253cl Display Replacement: passo 3, immagine 3 di 3
    • Remove any tape or wires that connect the screen and laptop together using tweezers.
  4. HP Pavilion x360 14-ba253cl Display Replacement: passo 4, immagine 1 di 1
    • Remove the display from the laptop.
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
If you came here looking for a lcd back cover replacement don't bother. You have to damage the new part to install. Horrible design.
Ender - Replica
This didn't help at all... You took as little pics as possible and didn't show the reinstall.
Cameron Coppoletta - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 110
Tutti i Tempi: 5,813
