Salta al contenuto principale
HP Pavilion x360 11-p110nr Wireless Chip Replacement
Cosa ti serve
  1. HP Pavilion x360 11-p110nr Wireless Chip Replacement, Wireless Chip: passo 1, immagine 1 di 3 HP Pavilion x360 11-p110nr Wireless Chip Replacement, Wireless Chip: passo 1, immagine 2 di 3 HP Pavilion x360 11-p110nr Wireless Chip Replacement, Wireless Chip: passo 1, immagine 3 di 3
    • Locate and remove all 11 of the screws.
    • Two of the screws will be underneath the rubber feet near the hinged edge of the bottom face
    • Detach the cover by slowly pulling it from the base of the computer.
    • Do not fully pull the cover off because there is a ribbon cable that needs to be removed first.
  2. HP Pavilion x360 11-p110nr Wireless Chip Replacement: passo 2, immagine 1 di 3 HP Pavilion x360 11-p110nr Wireless Chip Replacement: passo 2, immagine 2 di 3 HP Pavilion x360 11-p110nr Wireless Chip Replacement: passo 2, immagine 3 di 3
    • Locate and pull the ribbon cable.
    • Be sure to use the blue safety pull tab when removing it, as pulling on the cable itself could cause unwanted damage
  3. HP Pavilion x360 11-p110nr Wireless Chip Replacement: passo 3, immagine 1 di 3 HP Pavilion x360 11-p110nr Wireless Chip Replacement: passo 3, immagine 2 di 3 HP Pavilion x360 11-p110nr Wireless Chip Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • The wireless chip is square shaped, with white paper containing bar codes glued to it. The chip is in the top left section of the back (with the hinged edge facing away from you)
    • The chip will have a single wire connected to it. Carefully remove the wire connected to the chip using tweezers.
    • Unscrew the two screws near the top.
  4. HP Pavilion x360 11-p110nr Wireless Chip Replacement: passo 4, immagine 1 di 1
    • Remove the old chip and insert the new one in place.
    • When re-inserting the screws, be cautious as you do not want to strip the screws.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 400
