Salta al contenuto principale
HP Pavilion x360 11-p110nr Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion x360 11-p110nr  Hard Drive  Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  2. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: passo 2, immagine 1 di 1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion x360 11-p110nr.
    • Remove the nine screws from the back panel using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: passo 3, immagine 1 di 1
    • Remove the four screws holding in the hard drive compartment using a Phillips #0 screwdriver.
    • Pull the hard drive up and out to remove it from the compartment.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,978
