Salta al contenuto principale
HP Pavilion x2 10-n113dx Hinge Replacement
Cosa ti serve
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: passo 1, immagine 1 di 2 HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: passo 1, immagine 2 di 2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: passo 2, immagine 1 di 2 HP Pavilion x2 10-n113dx Hinge Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: passo 3, immagine 1 di 1
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: passo 4, immagine 1 di 2 HP Pavilion x2 10-n113dx Hinge Replacement: passo 4, immagine 2 di 2
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: passo 5, immagine 1 di 3 HP Pavilion x2 10-n113dx Hinge Replacement: passo 5, immagine 2 di 3 HP Pavilion x2 10-n113dx Hinge Replacement: passo 5, immagine 3 di 3
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: passo 6, immagine 1 di 2 HP Pavilion x2 10-n113dx Hinge Replacement: passo 6, immagine 2 di 2
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: passo 7, immagine 1 di 1
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: passo 8, immagine 1 di 1
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: passo 9, immagine 1 di 3 HP Pavilion x2 10-n113dx Hinge Replacement: passo 9, immagine 2 di 3 HP Pavilion x2 10-n113dx Hinge Replacement: passo 9, immagine 3 di 3
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: passo 10, immagine 1 di 3 HP Pavilion x2 10-n113dx Hinge Replacement: passo 10, immagine 2 di 3 HP Pavilion x2 10-n113dx Hinge Replacement: passo 10, immagine 3 di 3
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
Conclusione
Ajay Panuganti
Membro da: 04/01/19
181 Reputazione
1 Guida realizzata
IUPUI, Team S1-G4, Harley Spring 2019 Membro di IUPUI, Team S1-G4, Harley Spring 2019
IUPUI-HARLEY-S19S1G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,125
